I have a student lisence and in order to create a surface for my modeling, i have to import the STL file. but the factory item does not work and is not active.
Would you please guide me?
Hi Neda,
For EDEM factories you need:
Geometry can be Physical or Virtual when it comes to factories:
If the geometry is a Volume it can be Physical or Virtual, as we can create particles inside a Physical geometry or on a Virtual geometry.
If the geometry is a Surface it has to be set as Virtual for the factory, as we can only create particles on the virtual surface.
Regards
Stephen
