Access surface color data from parasolid
Bocaj22
Bocaj22 Altair Community Member
edited November 2023 in Community Q&A
Is it possible to access the color metadata attached to the surfaces in a parasolid (or other CAD format)? This would be useful to designate certain surfaces from our CAD platform prior to a hypermesh automation script. For example, green surfaces have a mesh size (or thickness) of 1 mm, red surfaces 1.5 mm, etc.
I have tried hm_metadata but do not see color as an option.
If not, any other ideas to label surfaces from a CAD program and recognize it in Hypermesh?
Thanks,
Jacob
Best Answer
  • Michael Herve
    Michael Herve
    edited November 2023 Answer ✓
    Hello @bocaj22 ,
    did you checked Color in the import pop-up when  loading a CAD:
    If so you should be able to use this command:
    hm_metadata findbyname COLOR_RGB
    and to get the color with rgb code:
    Does it help?
    Michael
  • Michael Herve
    Michael Herve
    Hello @bocaj22 ,
    Does it help?
    Michael
  • Bocaj22
    Hello @bocaj22 ,
    Does it help?
    Michael
    Michael,
    I did not realize it was an option during import. That solves it, thanks!
