Is there a way to change the background color of the main viewing window in Hyperworks? I believe you could do it in the old interface. It makes it easier to have easy to read tags if the background is darker.
Yeah, this is mostly possible from File->Preferences->Theme:
The dark theme is new to the more recent versions and is quite popular. Setting it to specific colors other than the present themes isn't an option.
Christian,
Thanks for the response. I forgot about the themes. Not quite what I had in mind, but I'll give it a try.
