What are the benefits of using Pulse over Hyperstudy? Are there key differences? They appear to accomplish similar things but in a different interface.
I see Pulse as being a way to automate a process that uses multiple applications that a specific project/model will be ran through the process once. Whereas, I see HyperStudy as a way to loop through a certain model to, in someway, optimize given parameters. HyperStudy could actually be a part of a Pulse project.
Hi bocaj22, Ben is right, Pulse is a powerful multi application engineering workflow creator, where you can build your own process modules and create all kinds of streamline processes.
The good news is that in the future Pulse will be able to leverage HyperStudy capabilities
