I've just begun using EDEM, and I'm having trouble understanding when reaction forces are captured. I have a model where an imported geometry collides with particles. I'd like to include some initial movement conditions on the geometry. I see in the documentation it says,
Unlike kinematics, you can add motion controllers to the geometry elements to allow objects to react to particle-geometry forces. Forces acting on the geometry are included in the calculation of the geometries motion. There is no contact detection between geometry elements. Sections pass through each other when they come into contact.
However, when I add a torque controller with an initial angular velocity, I don't see the reactionary forces I expect. In particular, the geometry does not move at all at the location where the initial angular velocity is applied. Does the torque controller create a joint at that location such that translation is prevented?
Thanks.
