Register Compose Function Hyperstudy
User: "Bocaj22"
Altair Community Member
Updated by Bocaj22
Does anyone know how to register a compose function for use in Hyperstudy? My understanding is to use the preference file, however, I do not know the proper keyword.
I suspect it is *RegisterOMLFunction, but i get an error saying 'Unable to load OML bridge (can't find HWX binary directory)'. I am able to register Hypermath functions without a problem.
Thanks,
Jacob
1 - 2 of 21
    User: "robertavarela"
    New Altair Community Member
    Updated by robertavarela
    In Compose, you must select the function's name and then hit the right mouse button. There is an option Register Function where you should click - once you did this, the Compose function is available to be used not only in HyperStudy, but also in other HW applications, such as HyperMesh and HyperView.
    Let me know if this does not work out for you.
    Roberta
    User: "Bocaj22"
    OP
    Updated by Bocaj22
    Roberta,
    Yes this works, thanks for your help!!
    -Jacob
