Minimum Size calculation method
Could anyone help me with this, What actually the LsDyna ISDO=0 calculation method, how it calculates the quality.
explain me how to clear the elements when it got failed, I know translate option to clear, but actually i need the back ground technical stuff behind it.
For Eg : for shortest edge calculation method, either one edge will fall under shorter value, so will identify that, will translate to pass the minimum size.
Thanks in advance.
from the documentation
Hi sir,
Thank You for you time.
Can You please explain me this thing with mathematical values, I need the idea for clearing the quality which fails under LSDYNA ISDO = 0, am not interested to do translate and clear the quality, without knowing the background behind it.
Thanks in advance.
