No key fields are defined
Altair Community Member
Updated by Ravi_22469
Hi
I have created 2 Models. I would like to create a third model. The third model will be a Database connection from SQL. I have had permission to acess SQL and specify which models I require.
I keep getting this error message;
When I clock "OK" it returns nothink under the "Data Preview";
I was thinking it would return all values from the SQL so I can then proceed to do a calculated in Model 3 from Models 1 & 2.
Any ideas on the above?
Funnily enough values from Both models labelled "TABLE1 and TABLE2" seem to appear on the Table view screen.
Thanks a lot.
Ravi
No comments on this post.
