Hi there! Does anyone know what this means exactly? I've downloaded version 2022.2 straight from Marketplace and while I can set up my model, I'm struggling to run a solve.
Optistruct does appear to be activated ...
Thanks
Hello Shindy,
Did you install at the same time "mechanical solvers"?
Marine Racollet
Hello Shindy, Did you install at the same time "mechanical solvers"? Regards, Marine Racollet
Hi Marine!
When downloading the software, I don't think I came across an option to select that...
Do you know how I may be able to go back and check or download that?
Hi Marine! When downloading the software, I don't think I came across an option to select that... Do you know how I may be able to go back and check or download that?
Hi Marine,
I've got it working now. Turns out I had the mechanical solver files in a different directory. Thanks for your help!
I had the exactly same issue as Shindy and i also checked the OptiStruct from "Solver Interface" tab.
And i haven't downloaded Mechanical Solver file yet from website. I immediately installed Mechanical Solvers and tried again. But i couldn't run my analysis again. The warning was again "Could not find Compute Console Script. Please install Solvers".
All my files about hypermesh are located in the "C:\Program Files\Altair" so i also installed my Mechanical Solver to same adress. But like i said, still having same issue "Could not find Compute Console Script. Please install Solvers".
Can you help me solve this problem?
HERE SAME ISSUE AM FACING ?
Please refer to the accepted solution. You need to also install the Mechanical Solvers with the Desktop exe using the Hyperworks Product installer per recommendations in the installation guide.
@Jason_Craanen, could you please elaborate on what you mean by "install the Mechanical Solvers with the Desktop.exe"? I am using a student version and had two separate '.exe' files for the solvers (hwSolvers2025_win64.exe) and for Hypermesh (hwDesktop2025_win64.exe).
You need to install both the Mechanical Solvers (OPtistruct for example) with Desktop (Hypermesh for Example) at the same time using the Product Installer
