Hello, I am trying to select the type of contour and deformation I want to view of my results through the Post tab in HyperMesh, however for some reason the settings which used to be there has disappeared . Any help would be much appreciated!!!
Can you close all your Altair application and delete temporary files?You can run the .bat file that you have in your installation folder to delete temporary files (Eg : C:\Program Files\2021.2\hwdesktop\utility\HWCleanup).(Warning, it will delete your preferences)
