HiI have a 3D model which I want to mesh according to two meshed surfaces as I mentioned in the photos.Is there a tool for this purpose?
It would be better to think long areas as along geometry instead of your willingness. Its easier, quicker and feasible for 3D HM algorithm most of the time unless if you like to see some mismatch errors at the bottom left Even I would rather choose to straight drag them and then project nodes to the side surface and lines to capture each part of surface maybe..
Especially for complex geometries, I offer you to check the morphing tools out as well.
Switch elements you want to use for drag with along direction ones. Select side ones (3) as elems to drag and longitudinal ones (1 - You want to drag) as elems along geometry after set it mixed. Use 4 lines which covers geometry with this elems for along geom settings.
