Altair RISE
Nominate Yourself Now!
Export Current on wire including boundary points
User: "ju1995"
Altair Community Member
Updated by ju1995
When investigating the .os file of the current on a dipole antenna, I recognized that the two boundary vertices, where the current should actually vanish, are not included in the .os file. I guess this is because the .os file contains the wire segments between the vertices instead of the vertices. How can I receive a .os file in which the current is zero at both boundary points of a wire antenna?
Thank you very much for your help!
1 - 1 of 11
    User: "GGAMPALA"
    Updated by GGAMPALA
    Feko writes the currents to the *.OS file that includes the physical position and the complex components of the current density vectors. So, it will be only the segments or the surface triangles and may not be possible to export it any different.
