Good evening,
after a simulation, I'd like to export all 1D results of Characteristic Mode Analysis (Eigenvalues, modal significance, modal excitation coefficients etc.) in a comfortable way to a txt file by using POSTFEKO, but I only seem to be able to export the Characteristic surface current. Is there a method to also export the mentioned 1D quantities?
My FEKO version is 2018.2.
Thank you very much for your help!
