I would like to define different multi-loadcases from a csv file but the loads I need to apply them in circular spots. Is that possible?
You can add circular spot from csv. You can also add Multi-loadcases from csv. But you need to create Forces on spots manually. If you do not use spot, you can create multiple forces on the coordinate point.
