Hello there,
I have a problem with running a Study (I've tried on Tutorial file and also on my own model).
After evaluation of Nominal run there is no .mrf file created in approach run folder, therefore I'm not able to set the proper response
(I'm not able to choose the file for Data Sources).
In MotionView analysis output options T've marked to create mrf file, and after MotionView Analysis there is such file created.
But unfortunately after HyperStudy nomial run there are just some other files but not the important one
/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
Thank you in advance
