Hello. I have been trying to use motionview/motionsolve for calculating bearing reaction force but i keep on ending up with a result with too much fluctuation.
My set-up is comprised of 4 gears meshing with each other and bearing for each of the gears.
I Tried to reduce the fluctuation by adjusting values in the COntact Properties and it somehow work after several trial and error.
Is there a proper way to determine contact properties for IMPACT?
What are the appropriate values for Stiffness, DAmping, Exponent?
And what are the best settings for gears contact? Impact, Poisson or volume model?
Thank you in advance
