Open IDA database for simulation in ProMan
User: "apallaprolu"
Altair Community Member
Updated by apallaprolu
I was trying to run ProMan through command line options and tried to set the following parameter in the .net file before execution:
CLUTTER_DATABASE_TRAFFIC './floorplan.ida'
However, the software opens up and seems to search for 'floorplan.idb' instead. Is there any way to use the IDA database to run ray tracing through ProMan? If not then is there a way to convert IDA database to IDB database over the command line?
Thanks!
Anurag.
1 - 1 of 11
    User: "mvogel"
    Updated by unknown
    It is possible to convert a .ida file to .idb through the WallMan graphical user interface via the menu File > Convert Indoor Database.
    I understand this is not an answer to the question, because you asked about a command-line conversion. I just wanted to mention the other conversion possibility.
