ASCII export data different from simulation output
User: "apallaprolu"
Altair Community Member
Updated by apallaprolu
I am doing a single omni TX indoor propagation experiment and have setup my prediction plane vertically oriented to the floor. Once the simulation is done I end up having the following files that are dumped
After displaying the results in the viewer if I export the power data of the prediction plane separately to a file:
I see that the ASCII dump (left) and the actual power data file for the TX logged during simulation (right) have discrepancies:
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.835c3b9c0afa018a646a9e65bc14986d.png
Can someone explain what could be causing the difference? I assumed the problem was with round-off but the third last entry (-27.79 vs -27.95) doesn't make sense.
Thanks!
Anurag.
1 - 2 of 21
    User: "Reiner_Hoppe"
    Updated by Reiner_Hoppe
    the observed differences are probably related to the activated filter settings in ProMan.
    Please disable the filters under Settings => Global settings, both on the Display tab (first line):
    and under the Computation tab and then try again:
    User: "apallaprolu"
    OP
    Thank you Reiner, it is consistent to round-off now.
    Thanks!
    Anurag.
