🎉Community Raffle - Win $25
Join and Win
Mistake when importing an input file (*.inp) from Abaqus
JJJUser: "JJJ"
Altair Community Member
Updated by JJJ
Dear friends,
I have a model calculated in Abaqus, and I want to analyze differences between this software and Optistruct. When I import the *.inp file into Hypermesh, the model is not imported properly. Why is happening this? I attach two pictures.
Thank you very much for your attention.
JJJ
1 - 7 of 71
    Most likely your abaqus mode has *part, *instance structure. You need to export your abaqus in flattened format.
    JJJUser: "JJJ"
    OP
    Updated by JJJ
    Dear afura,
    Thank you very much for your quick response. Sorry but this is the first time that I export from Abaqus to HyperMesh but, how I can export the abaqus model in flattened format? Thank you very much.
    JJJUser: "JJJ"
    OP
    Updated by JJJ
    Dear friends,
    Here I found the solution to my problem:
    https://abaqus-docs.mit.edu/2017/English/SIMACAECAERefMap/simacae-c-dbsflatteninput.htm
    In Hyperview, is it possible to visualize results from a *odb obtained in Abaqus?
    Regards.
    llyle_20499User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi JJJ,
    Yes, it is possible to view results from *.odb in Hyperview.
    Livil
    JJJUser: "JJJ"
    OP
    Updated by JJJ
    Hello Livil Lyle,
    Good morning, sorry for the delay to answer but I have been very busy this time. Could you please tell me how I can view the odb results in Hyperview? Thank you.
    Hi JJJ,
    Launch Hyperview -> Input the model and result file path
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.63bbfae652f25c249bde68705969ce75.png
    Click on Contour -> Select Result type, Result Component etc and press Apply to visualize the contour.
    For other option, please refer to help documentation.
     I have try to run a simply supported beam with point load at center.
    When I have assign value of damage in tension and compression for beam and run the problem execution of problem has aborted .
    This message has shown in message box, Abaqus FOUND NEGATIVE AND/OR DECREASING VALUES OF PLASTIC STRAIN. VERIFY THAT THE DEGRADATION DATA UNDER *CONCRETE TENSION DAMAGE IS CORRECT
    Error in job Job-1: DURING THE CONVERSION FROM CRACKING TO PLASTIC STRAIN Abaqus FOUND NEGATIVE AND/OR DECREASING VALUES OF PLASTIC STRAIN. VERIFY THAT THE DEGRADATION DATA UNDER *CONCRETE TENSION DAMAGE IS CORRECT
    can any one solve this problem.
