I have tried to request EFFMASS > YES in Process for Normal modes, but there are 2 problems : in the output file after the run, there are no mass participation factors calculated. I have to create the request in Solver tab under Parameter.
The other problem is that once I make a request in Process section, I can not know if it is done properly or not, once I am done with the process, there is nothing saved in the Process tab, so I can not know how to undo it, on which nodes have I requested and so, so this tool is not 100% useful. It was better that it left a trace of the operations requested by user
another question about the Modal participation factors, why is it calculated differently and multiple times in my out file for one simple beam ?
ITERATION 0
(Scratch disk space usage for starting iteration = 1 MB)
(Running in-core solution)
Volume = 1.00000E+05 Mass = 7.85000E-04
Generalized Generalized
Subcase Mode Frequency Eigenvalue Stiffness Mass
1 1 8.348723E+00 2.751692E+03 2.751692E+03 1.000000E+00
1 2 8.370546E+00 2.766097E+03 2.766097E+03 1.000000E+00
1 3 5.229004E+01 1.079438E+05 1.079438E+05 1.000000E+00
1 4 5.244297E+01 1.085761E+05 1.085761E+05 1.000000E+00
1 5 1.465769E+02 8.481857E+05 8.481857E+05 1.000000E+00
1 6 1.471071E+02 8.543332E+05 8.543332E+05 1.000000E+00
1 7 2.880508E+02 3.275654E+06 3.275654E+06 1.000000E+00
1 8 2.894193E+02 3.306852E+06 3.306852E+06 1.000000E+00
1 9 4.784141E+02 9.035822E+06 9.035822E+06 1.000000E+00
1 10 4.814465E+02 9.150732E+06 9.150732E+06 1.000000E+00
1 11 6.241844E+02 1.538103E+07 1.538103E+07 1.000000E+00
1 12 7.195347E+02 2.043917E+07 2.043917E+07 1.000000E+00
2 1 1.165734E-03 -5.364860E-05 -5.364860E-05 1.000000E+00
2 2 8.828066E-04 -3.076741E-05 -3.076741E-05 1.000000E+00
2 3 7.342745E-04 2.128514E-05 2.128514E-05 1.000000E+00
2 4 8.444623E-04 2.815272E-05 2.815272E-05 1.000000E+00
2 5 9.689701E-04 3.706641E-05 3.706641E-05 1.000000E+00
2 6 1.576366E-03 9.810110E-05 9.810110E-05 1.000000E+00
2 7 5.278576E+01 1.100002E+05 1.100002E+05 1.000000E+00
2 8 5.282278E+01 1.101545E+05 1.101545E+05 1.000000E+00
2 9 1.450874E+02 8.310345E+05 8.310345E+05 1.000000E+00
2 10 1.453309E+02 8.338264E+05 8.338264E+05 1.000000E+00
MODAL PARTICIPATION FACTORS FOR SUBCASE 1
RIGID BODY MODES BASED ON REFERENCE POINT AT ORIGIN OF BASIC COORDINATE SYSTEM
Mode Frequency X-TRANS Y-TRANS Z-TRANS X-ROTAT Y-ROTAT Z-ROTAT
1 8.349E+00 -6.851E-16 2.192E-02 -4.214E-11 -2.107E-10 3.066E-08 1.595E+01
2 8.371E+00 -1.699E-17 4.216E-11 2.191E-02 1.096E-01 -1.594E+01 3.067E-08
3 5.229E+01 -8.708E-17 -1.214E-02 -1.211E-12 -6.056E-12 2.565E-10 -2.550E+00
4 5.244E+01 7.671E-19 1.208E-12 -1.214E-02 -6.071E-02 2.560E+00 2.525E-10
5 1.466E+02 3.297E-16 -7.105E-03 8.622E-15 4.333E-14 -6.622E-13 -9.136E-01
6 1.471E+02 4.567E-18 -9.816E-15 -7.110E-03 -3.555E-02 9.201E-01 -1.325E-12
7 2.881E+02 1.847E-16 -5.064E-03 2.777E-15 1.387E-14 -2.360E-13 -4.682E-01
8 2.894E+02 2.704E-18 2.807E-15 5.073E-03 2.537E-02 -4.730E-01 2.550E-13
9 4.784E+02 2.676E-16 3.923E-03 9.790E-16 4.820E-15 -6.830E-14 2.848E-01
10 4.814E+02 1.995E-18 8.108E-16 -3.936E-03 -1.968E-02 2.884E-01 2.926E-14
11 6.242E+02 7.186E-17 1.664E-17 8.233E-15 -1.261E-01 -6.724E-12 -1.920E-14
12 7.195E+02 -4.356E-16 3.195E-03 -1.211E-15 -4.858E-15 1.750E-14 1.919E-01
SUBCASE TOTAL -3.609E-16 4.726E-03 3.797E-03 -1.071E-01 -1.265E+01 1.249E+01
MODAL PARTICIPATION FACTORS RATIOS FOR SUBCASE 1
1 8.349E+00 1.000E+00 1.000E+00 1.923E-09 1.671E-09 1.923E-09 1.000E+00
2 8.371E+00 2.481E-02 1.923E-09 1.000E+00 8.691E-01 1.000E+00 1.923E-09
3 5.229E+01 1.271E-01 5.540E-01 5.528E-11 4.804E-11 1.609E-11 1.599E-01
4 5.244E+01 1.120E-03 5.508E-11 5.541E-01 4.816E-01 1.606E-01 1.583E-11
5 1.466E+02 4.812E-01 3.241E-01 3.935E-13 3.437E-13 4.154E-14 5.729E-02
6 1.471E+02 6.666E-03 4.478E-13 3.245E-01 2.820E-01 5.771E-02 8.306E-14
7 2.881E+02 2.697E-01 2.310E-01 1.267E-13 1.100E-13 1.480E-14 2.936E-02
8 2.894E+02 3.947E-03 1.281E-13 2.315E-01 2.012E-01 2.966E-02 1.599E-14
9 4.784E+02 3.907E-01 1.790E-01 4.468E-14 3.824E-14 4.284E-15 1.786E-02
10 4.814E+02 2.912E-03 3.699E-14 1.796E-01 1.561E-01 1.809E-02 1.835E-15
11 6.242E+02 1.049E-01 7.589E-16 3.757E-13 1.000E+00 4.218E-13 1.204E-15
12 7.195E+02 6.359E-01 1.457E-01 5.529E-14 3.854E-14 1.098E-15 1.203E-02
MODAL EFFECTIVE MASS FOR SUBCASE 1
1 8.349E+00 4.694E-31 4.806E-04 1.776E-21 4.439E-20 9.401E-16 2.543E+02
2 8.371E+00 2.888E-34 1.777E-21 4.801E-04 1.200E-02 2.542E+02 9.404E-16
3 5.229E+01 7.583E-33 1.475E-04 1.467E-24 3.668E-23 6.581E-20 6.504E+00
4 5.244E+01 5.884E-37 1.458E-24 1.474E-04 3.685E-03 6.554E+00 6.374E-20
5 1.466E+02 1.087E-31 5.049E-05 7.434E-29 1.877E-27 4.385E-25 8.347E-01
6 1.471E+02 2.086E-35 9.636E-29 5.055E-05 1.264E-03 8.467E-01 1.754E-24
7 2.881E+02 3.413E-32 2.565E-05 7.713E-30 1.923E-28 5.568E-26 2.192E-01
8 2.894E+02 7.311E-36 7.881E-30 2.574E-05 6.434E-04 2.237E-01 6.503E-26
9 4.784E+02 7.163E-32 1.539E-05 9.585E-31 2.323E-29 4.665E-27 8.110E-02
10 4.814E+02 3.980E-36 6.574E-31 1.549E-05 3.873E-04 8.318E-02 8.560E-28
11 6.242E+02 5.165E-33 2.768E-34 6.778E-29 1.589E-02 4.521E-23 3.688E-28
12 7.195E+02 1.898E-31 1.021E-05 1.467E-30 2.360E-29 3.062E-28 3.683E-02
SUBCASE TOTAL 8.867E-31 7.298E-04 7.193E-04 3.387E-02 2.619E+02 2.620E+02
MODAL EFFECTIVE MASS FRACTION FOR SUBCASE 1
1 8.349E+00 5.979E-28 6.122E-01 2.262E-18 1.131E-18 3.588E-18 9.704E-01
2 8.371E+00 3.679E-31 2.264E-18 6.116E-01 3.058E-01 9.702E-01 3.589E-18
3 5.229E+01 9.659E-30 1.879E-01 1.869E-21 9.345E-22 2.512E-22 2.482E-02
4 5.244E+01 7.496E-34 1.857E-21 1.878E-01 9.389E-02 2.502E-02 2.433E-22
5 1.466E+02 1.385E-28 6.431E-02 9.470E-26 4.783E-26 1.674E-27 3.185E-03
6 1.471E+02 2.657E-32 1.228E-25 6.439E-02 3.219E-02 3.232E-03 6.696E-27
7 2.881E+02 4.348E-29 3.267E-02 9.825E-27 4.899E-27 2.125E-28 8.366E-04
8 2.894E+02 9.314E-33 1.004E-26 3.279E-02 1.639E-02 8.538E-04 2.482E-28
9 4.784E+02 9.125E-29 1.961E-02 1.221E-27 5.919E-28 1.780E-29 3.095E-04
10 4.814E+02 5.070E-33 8.375E-28 1.974E-02 9.869E-03 3.175E-04 3.267E-30
11 6.242E+02 6.579E-30 3.526E-31 8.634E-26 4.048E-01 1.726E-25 1.407E-30
12 7.195E+02 2.418E-28 1.300E-02 1.869E-27 6.012E-28 1.169E-30 1.405E-04
SUBCASE TOTAL 1.130E-27 9.297E-01 9.163E-01 8.630E-01 9.996E-01 9.997E-01
MODAL PARTICIPATION FACTORS FOR SUBCASE 2
1 0.000E+00 -4.621E-04 1.831E-02 -1.914E-06 -1.558E-05 9.265E-04 3.022E+00
2 0.000E+00 8.521E-04 -2.118E-02 -3.435E-06 -1.443E-05 3.681E-03 -1.590E+01
3 7.343E-04 1.038E-05 8.461E-08 2.746E-02 1.448E-01 -1.219E+01 -8.036E-04
4 8.445E-04 -2.092E-05 -6.092E-06 5.371E-03 2.470E-02 -1.064E+01 -4.426E-03
5 9.690E-04 -2.800E-02 -9.469E-04 6.170E-06 2.814E-05 3.503E-03 -3.935E-01
6 1.576E-03 1.453E-06 -1.086E-06 1.377E-03 -1.330E-01 -4.839E-01 -4.086E-04
7 5.279E+01 -1.201E-13 -1.044E-12 -3.995E-15 -2.086E-14 2.794E-12 5.275E-10
8 5.282E+01 -2.491E-15 3.883E-16 1.805E-12 1.118E-11 -9.251E-10 4.554E-13
9 1.451E+02 -3.970E-14 -1.284E-13 -3.332E-16 -2.442E-15 2.575E-13 -1.340E-11
10 1.453E+02 2.677E-17 -1.796E-16 3.000E-14 2.739E-15 3.071E-11 -7.473E-14
SUBCASE TOTAL -2.762E-02 -3.828E-03 3.421E-02 3.646E-02 -2.330E+01 -1.328E+01
MODAL PARTICIPATION FACTORS RATIOS FOR SUBCASE 2
1 0.000E+00 1.650E-02 8.644E-01 6.969E-05 1.076E-04 7.603E-05 1.901E-01
2 0.000E+00 3.043E-02 1.000E+00 1.251E-04 9.971E-05 3.020E-04 1.000E+00
3 7.343E-04 3.708E-04 3.994E-06 1.000E+00 1.000E+00 1.000E+00 5.055E-05
4 8.445E-04 7.470E-04 2.876E-04 1.955E-01 1.706E-01 8.733E-01 2.784E-04
5 9.690E-04 1.000E+00 4.470E-02 2.247E-04 1.944E-04 2.874E-04 2.475E-02
6 1.576E-03 5.188E-05 5.124E-05 5.014E-02 9.187E-01 3.971E-02 2.570E-05
7 5.279E+01 4.289E-12 4.930E-11 1.455E-13 1.441E-13 2.293E-13 3.318E-11
8 5.282E+01 8.895E-14 1.833E-14 6.573E-11 7.725E-11 7.592E-11 2.864E-14
9 1.451E+02 1.418E-12 6.062E-12 1.213E-14 1.687E-14 2.113E-14 8.429E-13
10 1.453E+02 9.559E-16 8.479E-15 1.092E-12 1.892E-14 2.520E-12 4.701E-15
MODAL EFFECTIVE MASS FOR SUBCASE 2
1 0.000E+00 2.135E-07 3.353E-04 3.663E-12 2.427E-10 8.585E-07 9.130E+00
2 0.000E+00 7.261E-07 4.488E-04 1.180E-11 2.083E-10 1.355E-05 2.527E+02
3 7.343E-04 1.078E-10 7.158E-15 7.543E-04 2.095E-02 1.485E+02 6.457E-07
4 8.445E-04 4.375E-10 3.711E-11 2.884E-05 6.102E-04 1.133E+02 1.959E-05
5 9.690E-04 7.841E-04 8.966E-07 3.807E-11 7.919E-10 1.227E-05 1.548E-01
6 1.576E-03 2.110E-12 1.178E-12 1.896E-06 1.769E-02 2.342E-01 1.669E-07
7 5.279E+01 1.443E-26 1.091E-24 1.596E-29 4.350E-28 7.806E-24 2.783E-19
8 5.282E+01 6.204E-30 1.508E-31 3.259E-24 1.250E-22 8.558E-19 2.073E-25
9 1.451E+02 1.576E-27 1.649E-26 1.110E-31 5.965E-30 6.631E-26 1.796E-22
10 1.453E+02 7.164E-34 3.226E-32 8.998E-28 7.503E-30 9.429E-22 5.585E-27
SUBCASE TOTAL 7.850E-04 7.850E-04 7.850E-04 3.925E-02 2.620E+02 2.620E+02
MODAL EFFECTIVE MASS FRACTION FOR SUBCASE 2
1 0.000E+00 2.720E-04 4.271E-01 4.666E-09 6.183E-09 3.277E-09 3.484E-02
2 0.000E+00 9.250E-04 5.717E-01 1.503E-08 5.308E-09 5.171E-08 9.646E-01
3 7.343E-04 1.373E-07 9.119E-12 9.608E-01 5.338E-01 5.668E-01 2.464E-09
4 8.445E-04 5.574E-07 4.728E-08 3.674E-02 1.555E-02 4.323E-01 7.477E-08
5 9.690E-04 9.988E-01 1.142E-03 4.850E-08 2.018E-08 4.683E-08 5.909E-04
6 1.576E-03 2.688E-09 1.501E-09 2.415E-03 4.506E-01 8.939E-04 6.371E-10
7 5.279E+01 1.838E-23 1.390E-21 2.033E-26 1.108E-26 2.980E-26 1.062E-21
8 5.282E+01 7.903E-27 1.921E-28 4.151E-21 3.185E-21 3.267E-21 7.913E-28
9 1.451E+02 2.008E-24 2.101E-23 1.414E-28 1.520E-28 2.531E-28 6.854E-25
10 1.453E+02 9.126E-31 4.110E-29 1.146E-24 1.912E-28 3.599E-24 2.132E-29
SUBCASE TOTAL 1.000E+00 1.000E+00 1.000E+00 1.000E+00 1.000E+00 1.000E+00
ANALYSIS COMPLETED.
