Hi All
I have imported an assembly from Catia file and also from a single part Catia containing same parts, but they get imported all in gray! It gets too time consuming to correct them in Hyperworks! is there any automatic way for that?
I also need an advice: I work on an electronic board. So one way was importing it into Simlab, but I found it very incomplete in order to create bolted connections. should I have done it there? it was easier to mesh, but I stopped in connector creation. I just needed to create the RBE2 elements, should I do all in Hyperworks and then how to export it to simlab or how to export it to Abaqus?
also: since the parts in CATIA are imported from Altium, some of them are shell and some solid : how do I convert a shell to solid? how do make a shell structure rigid?
sorry for many question in one post
