I'm trying some meshing techniques for some simulations, and I would like to know how it is the best way to mesh a face / Volume / Region / ...
I suppose that depending the meshing quantity, I'll get different results.
And also, the best meshing way for the user depends on applying the less meshing point quantity, for the most precise result. Saying in other words, if I add more points in the meshing tool, the result will not change.
Correct me if I'm wrong please, but is it true that the check mesh checks the precision of the mesh in all the system? Including Aided & Relaxation mesh areas.
And how would be the way to check the mesh of an specific face, volume, region, line... without drawing upon the solver?
