impossible to import the STL file in 3D project
User: "Fausto Franchini"
Altair Community Member
Updated by Fausto Franchini
Dear Altair Community,
we found following error after to try to import the STL file in 3D project (flux version 2019.1):
stdcom.error.SoftwareFortranException: Failed execution
    at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:170)
    at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method)
    at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:902)
    at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
    at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2180)
    at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:2046)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:206)
    at org.python.core.PyObject.__call__(PyObject.java:526)
    at org.python.core.PyObject.__call__(PyObject.java:530)
    at org.python.core.PyMethod.__call__(PyMethod.java:156)
    at pydb$py.executeCommand$204(pydb.py:1608)
    at pydb$py.call_function(pydb.py)
    at org.python.core.PyTableCode.call(PyTableCode.java:171)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:171)
    at org.python.core.PyFunction.__call__(PyFunction.java:434)
    at pydb$py.__call__$177(pydb.py:1423)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:199)
    at org.python.core.PyFunction.__call__(PyFunction.java:482)
    at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
    at org.python.core.PyMethod.__call__(PyMethod.java:228)
    at org.python.core.PyMethod.__call__(PyMethod.java:223)
    at org.python.core.PyObject.invoke(PyObject.java:3715)
    at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
    at org.python.core.PyInstance.__call__(PyInstance.java:372)
    at org.python.core.PyObject.__call__(PyObject.java:424)
    at org.python.pycode._pyx132.f$0(<input>:1)
    at org.python.pycode._pyx132.call_function(<input>)
    at org.python.core.PyCode.call(PyCode.java:18)
    at org.python.core.Py.runCode(Py.java:1625)
    at org.python.core.Py.exec(Py.java:1669)
    at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
    at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:628)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:623)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:598)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:593)
    at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:638)
    at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:706)
    at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(CommandServerRequestsRouter.java:70)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(CommandServerRequestsOutputPlug.java:111)
    at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:692)
    at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
    at cad.flux.frontal.actions.implementation.algo.project.StandardAlgoAction.executeBox(StandardAlgoAction.java:90)
    at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
    at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
    at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
    at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
    at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
1 - 1 of 11
    User: "Mohammed Elamin_22169"
    New Altair Community Member
    Updated by Mohammed Elamin_22169
    Hi Fausto,
    This error message is very general and doesn't indicate what is the problem. If possible can you share the STL file  and I can check further. keep in mind this is a public forum, if you can't share the file here, please open a support ticket and attach the file to it.
    Another possibility is to try to convert the STL file to a solid body in other format (STPES,IGES,...etc) and then import it as CAD model in Flux.  I believe this will be more stable than STL import.
    Thanks,
