How to retrieve elements by 'by face ' option.
1.i will select two elements in mask panel.
2.then i will go by face option .
3.i need selected face elements.
if you already pick 2 elems on mask panel, to mark others on face, use commands:
*appendmark elems 1 'by face'
hm_highlightmark elems 1 h; #just help you see which elems selected
and above command cannot append mark on level-2 panel, so if you stack mask panel on another, it will not work!
thanks tinh
