Defining a fixed joint between two parts the origin point must be defined explicitly in motionview. Where do we have to define this point? does the location of the origin point for fixed joint effects the solution?
Hi @HyperX
Sorry for a late reply. Somehow I missed this post.
Please see the image below which explains what makes the difference when the origin location is changed.
