hello,
i use the hyperworks 2017 version, and i can not find the parameters to set EOS in radioss block format, i need to define a material which is elastic plastic hydrodynamic material?
i am beginner in radioss, thanks very much!!!
Hello @meng2019
EOS is classified as property in HyperMesh.
If you know the keyword of RADIOSS card, you can create the entity from Tools pulldown menu.
Thanks,
Imoto
