2.45GHz Patch Antenna Simulation
Marcus Chang
Marcus Chang Altair Community Member
Dear support team,
Recently I try to simulate a very simple patch antenna working at 2.45 GHz, but it show an error message as below, please check it:
ERROR 3849: Wrong specification of the medium for a metallic triangle
and I try to open POSTFEKO and use 'Find Element' method, to see the problems occurs by which triangle, but two meshes seemed like not overlap.
<?xml version="1.0" encoding="UTF-8"?>Capture.thumb.PNG.4c1bdcf53fe2d458db5937d425b3f7da.PNG
can you help us check what's going on in my simulation?
Thanks a lot!
BR/Marcus
  • Mel
    Mel
    edited May 2019
    Hi Marcus
    I see there are many parts in the geometry tree. For a continuous mesh to be generated, you must Union all the parts.
    Then you must set the appropriate Region and Face properties.
    I would also rather use a waveguide port.
  • Marcus Chang
    edited May 2019
    Dear Mel,
    I have tried to union all the parts, and it still didn't work.
    And also, due to there is an error if I use waveguide port, so I use lump port alike, to excite it.
    It would be grateful if you can help us modify the settings for this simulation.
    BR/Marcus
  • Marcus Chang
    edited June 2019
    Dear Mel,
    Is there any update for the modified .cfx file?
    Looking forward receiving your response.
    BR/Marcus
  • Mel
    Mel
    edited June 2019
    It would be simpler to first get the design working with a simpler port construction, such as the edge feed.
    Attach the cfx.
