Dear all,
Recently, I try to use a near field data as the source, and try to get it's far field results.
However, it shows a warning message as below:
WARNING 3411: No accurate power calculation possible if two non-orthogonal elementary dipoles of the same type are at the same position
Received message from server process 2:
WARNING 2407: Computation of the near field of a Hertzian dipole not possible at the dipole location
Could you help us check what does it exactly mean in this case?
Is there any solution to solve it?
BR/Marcus
