Hi all,
Please advise if there is a way in which I can obtain difference heat maps for more than 1 antenna in the prediction rectangle.
for Example, firstly load 4 antennas into the prediction rectangle using Edit --> Combine data --> Max value. Then, subtract this combined heat map with another combined heat map with 4 antennas which were already loaded using Edit --> Subtract --> Value (File, Linear) . So Its basically 4 antennas - 4 antennas.
Is it possible in ProMan.
Please advise
Thanks
Have a great day
Balaji
