I am new to flux environment and I have been modelling simple EM use cases. One such use case is H field calculation for a single conductor carrying current in air medium.
   	I drew and plotted the magnetic field magnitude (A/m) using the sensor functionality. I am however finding it hard to compare the result with hand calculations. The expression for H is Current/(2Xpi X distance). The simulation result does not seem to match with the hand calculation. I see the result is off by the order of 10^6. I suspect, I may be reading the units erroneously. Please lend any help in understanding the output units of flux simulations.
