Hi Chuck,I tried it with an Excel external lookup file in Monarch 14.3 and I could see the first 255 columns. What 'sub' version of Monarch and file formats are you using?As a workaround, would it be possible to 'prep' your external lookup as a separate process into a more manageable file?Regards,Steve.------------------------------Steve CaielsProfessional ServiceDatawatch Corporation+44 203 868 0253-------------------------------------------------------------------------Original Message:Sent: 03-28-2019 09:21 AMFrom: Charles ZawadskiSubject: Max columns for External LookupTrying to create an external lookup to a table with a large number of columns. On the External Lookup Fields tab, Monarch 14 only seems to show the first 100 columns and is not showing me the column I'm looking for. Is this a limitation or is there a configuration somewhere?------------------------------Chuck ZawadskiPrincipal EngineerPeople's United Bank, National AssociationBRIDGEPORT CT------------------------------"
