Hi Erman,
You can switch on the load handle from the bottom panel.
See the attached image.
Thanks
Rajashri
Hi Erman, You can switch on the load handle from the bottom panel. See the attached image. Thanks Rajashri
Here is the attachment.
not showing up bro
Did you switch on the load handle?
I have sent the image pic, did you check?
In Preference, switch on the constraint labels and dof.
Let me know if this works.
