Hi everyone,
I need to define a surface from a set of lines that represent level curves of a set of mountains. The creation of surfaces from lines does not work well.
Is there a way to obtain good surfaces?
Bests
Martina
could you please share the line data for the test?Or some screenshot is also fine.
Hi Rahul,
here the .fem file of the lines set.
Thank you!
Shared fem file is empty.Fem files only contains FEM entity. For sharing lines you should share .Hm file.
I'm sorry.
Is this the correct file?
looks pretty complex.I did try creating surfaces with skin option for some parallel lines.CAD software should provide good option.
Thank you Rahul!
