I'm attempting to set up a simulation to see the suction pressures generated by a heat exchanger fan. I ran into an issue with setup that I could use some help with. I have very limited information on the heat exchanger itself (dimensions and CFM). Is there a way to have a set CFM or velocity through an outlet and have the inlet act as open atmosphere? My first attempt was to set the inlet on the atmosphere side and have the outlet at 0 pressure but this gave me the opposite of what I wanted, forcing air into the system rather than pulling it out the fan.
Thanks
