Hi!
I am trying to create a mulltibody model of a 2 stages planetary gearing system. When I insert the first contact, gears work correct, when I insert the second, I get the message : Contact graphics undefined for contact force [id=301001]!
When i try different set of gears, the same error appears for the second contact.
Is there a constrain for the student version ? Or I should try to change my CAD files ?
I want to perform a dynamic analysis and stress calculations for one of the gears, that's why i have to use contacts and no couplers.
Thank you in advance for your help !
