Hi, I’m trying to run feko lua scripts from command line to change some variables inside cadfeko with a call from CLI.
When I run the script from the feko script editor it works fine but when I try to execute it from terminal it does not work and the message
”An error occurred while processing the command line:Loaded “FILENAME.cfx” Data could not be read from file “FILENAME.cfx” An unknown error occurred”
The command I run is :
cadfeko “FILENAME.cfx” —run-script ChangeVar.lua
How can I fix this error?
Thanks in advance for the help.
