Hi!
I tried “Tool – faces – tolerance adjust to 4 -- equivalent”, it turns out poor mesh quality and still not many nodes are merged. Then ' Imprint' but elements should be shells.
Is there an easy function?
Cheers!
Faces we check to ensure the connectivity between 3d elements. Please share the screenshot of the region where you want to maintain connectivity.
Hi Rahul,
Thanks, is has been solved. I deleted 2D surface, use find face of 3D surface, then equivalence.
