Using CFD-DEM coupling, should the diameter in the material settings in CFD be the same as the particle diameter in EDEM?
Hi xixihaha
The diameter value in HMCFD is not used for calculations. The particle properties are sent by EDEM to the CFD solver.
Hope this helps.
Thanks,Jerrin Job
Hi xixihaha The diameter value in HMCFD is not used for calculations. The particle properties are sent by EDEM to the CFD solver. Hope this helps. Thanks,Jerrin Job
Thank you very much for your reply.What is the diameter set for?
That value is not used for anything. Please ignore that. That field will not be available in future versions.
Hi xixihaha That value is not used for anything. Please ignore that. That field will not be available in future versions. Thanks,Jerrin Job
