Does anyone have the .dll file (CUDA GPU) of the BondedParticle_CM_v3_1_0 model?
Can you share it with me?
Thank you
https://community.altair.com/community/en/edem-api-contact-model-example-updated-bond-model-example-of-customisation?id=kb_article&sysparm_article=KB0122075
The 3.1 API doesn't support CUDA, this was implemented in API 3.3 (EDEM 2021.2 onwards) however I'd recommend using the latest version if you have this available.
We have a guide for updating API versions here:
EDEMAPI
Regards
Stephen
Hi, The 3.1 API doesn't support CUDA, this was implemented in API 3.3 (EDEM 2021.2 onwards) however I'd recommend using the latest version if you have this available. We have a guide for updating API versions here: EDEMAPI Regards Stephen
thanks
in this case, I can use the CPU to calculate the model, but not the GPU.
