Hi!
I have this problem couple of times by Hypemesh.:( I trim the Solid with lines – by vertor (z direction)- sweep all. Then the Solids turns out non- mappable. The same way with no curve of the solid, it still turns out non mappable.
Some one can tell me why this is keep happening?
Thanks in advance!
