How to import CAD data via script including all options?
User: "Manuel Armbruester"
Altair Community Member
Updated by Manuel Armbruester
Hello alls,
For importing CAD CATIA data into HyperMesh I want to create a macro instead of using the import-GUI.
Background:
we are using PartBrowser (import as parts) with defined entries for PDM-data and using a config-file.
To do all this by the user => will result in errors....
Problem:
I know, there is a command called "*feinputwithdata2"
But i d not know, how to provide all the required info to this one... (name of config file, to import as parts instead of as assemply/component and so on...)
Question:
Can someone tell me or provide an existing script,
how the "*feinputwithdata2" has to be set up to control all the options which I have in CAD-Import-GUI available?
Or can anybody tell me a different command for this...
Thanks a lot
and best regards
Manuel
1 - 4 of 41
    User: "Adriano_Koga"
    Updated by Adriano_Koga
    I don't have the full description for this command, but usually waht I do is to open the GUI, import a few files manually, setting the desired options on importing, and after doing this, I open the 'command.tcl' and check the options written there. Usually this is quicker than figuring out all options.
    User: "Sanaa Mouzahir"
    Updated by Sanaa Mouzahir
    That is a good idea! Could you give more details ? I want to run a Macro that imports a Solidworks File. According to what you wrote I should be able to just import the file manually, then find the code on the tcl console ?
    I don't see anything on the console, but maybe I did not understand properly ? Thank you already.
    everything you do in HM is recorded to a file named 'command.tcl'.
    From the menus, you can open the contents of it, with each command that you've used manually.
    From there, you can copy the commands, search at the Help and automate these, by combining TCL commands, and create your own script. There are a few basic tutorials in the help of HyperMesh.
    Usually the command.tcl files are written to your working directory, which tipically is Documents folder.
    Thank you for this extremely helpful insight. I tried this and indeed obtained a tcl file named 'Command1.tcl'.
    The thing is, when I copy what I have in the file to the console or to Python (Using tkinter), I obtain errors such as:invalid command name "*createstringarray", indicating the commands of the file are invalid.
    I am a little lost regarding what I should do to solve the issue. Any leads?
    Thank you so much!
