The results from a simulation solved in a cluster can't be visualized in postfeko the graphs are empty and on the traces there is a message "missing data". What could be the reason ?
Thank you,
Alfred
Hi Alfredo,
Can you please check your simulation folder and see whether you have *.fek and *.bof available. Usually, PostFeko requires these files to visualize the data.
Thanks!
Raja
