where to get the animation toolbar in the 2022.2 version?
Thank you
Do you mean the animation playback controls? They should be there if you have transient results, click gear icon to get the full controls. (If you don't have them visible, try reloading your results)
If you are referring to the animation capture controls, they are under File --> Screen Capture
not seeing that option in the HV window as shown below picture. where to find that animation toolbar?
not seeing that option in the HV window as shown below picture. where to find that animation toolbar? Thank you
have you launched the 'Results' buttom after running your model?
I've noticed that when we do that, the animation control is missing too. But as a workaround, if you 'add' a new page (blank) is will appear, and then you can go back to your previous page.
I had the same issue. I tried following @Adriano A. Koga 's advice but still couldn't get it to pop up. I found that I needed to add a step. If I open a second blank window, and within the new blank window, select Hypermesh, then toggle back to my Hyperview window - the animation toolbar comes back. This is version 2022.3.
Your method can work.
I use your method to get the animation toolbar back again
