Goodevening everyone, I'm Giulio. I'm tryng to make a boolean combine between 2 body but always the smaller desappear after the operation, why? How can I fix the issue?
Thank you
Hi Giulio,
Are you performing boolean operation on 2 solid entities ?
BR-
Thomas
Hi Giulio, Are you performing boolean operation on 2 solid entities ? BR- Thomas
Thank you for your reply. One entity is a polynurbs, the other is a "new part" drowed into inspire
Here the imagine
What is the version you are using ?
The Boolean operation available on polynurbs has been available in the late versions.
What is the version you are using ? The Boolean operation available on polynurbs has been available in the late versions. BR- Thomas
2019.3.3
Do you have access to a more recent version ? We juste release 2021 version in January.
Do you have access to a more recent version ? We juste release 2021 version in January. BR- Thomas
No. Is not possible doing boolean combine on polynurbs in 2019.3.3?
If can be usfull, I tried now to mirror the frame and combine it, and it works.
I just tested in version 2019.4 and it works. But I noticed that when you combine, the solid disapears.
You have then to exit the combine to to make everything appears agains. Does it work in you case ?
