How to run a tcl-script in new HyperWorks 2023?
The help is misleading:
Run Scripts
I can find neither a "Run" in the File menu, nor a "Standard toolbar", nor a "Utility" menu.
Sad bad true ...
Kind regards,Arno
Hi Arno, Please find the options here in the attached image to run the .tcl scripts. Regards, Sriramanuj Prabhu.
Hi Arno,
Sriramanuj Prabhu.
Hey Arno,
You can also drag and drop your .tcl file into the Tcl command window. To enable it, go to View Menu > Tcl Command Window
Kind regards,Paulo Libório.
Many thanks, Sriramanuj Prabhu!Still, the manual should be updated.
Many thanks, Sriramanuj Prabhu!Still, the manual should be updated. Kind regards,Arno
We are currently in the process of updating, and it will be addressed shortly.
Thank you so much ????.
