Whenever I import an assembly Hypermesh is creating an assembly for almost every part. The actually assemblies still work, but having 110 "assemblies" where there are only a handful makes locating the proper ones difficult. The assembly hierarchy is also not tabbed, so without clicking them you cannot see what the assemblies are comprised of. I've tried several combinations of import method, but get the same result each time. This occurs when importing from a step file or a Creo assembly.
Is there a way to force assemblies to be only created for actual assemblies?
