i'm trying to write the ids of specific selected nodes within a mesh to a text file, but i can't find a suitable tcl command.
Can somebody help me?
Thank you very much!
Hello.I can export the Node ID and coordinates from HyperWorks (HyperMesh) to a CSV file using the Tcl source in the attached file.If you want to export Node IDs and coordinates from HyperView, it will be a different program.
Thank you.
Hello.I can export the Node ID and coordinates from HyperWorks (HyperMesh) to a CSV file using the Tcl source in the attached file.If you want to export Node IDs and coordinates from HyperView, it will be a different program. Thank you.
That works perfectly, Thank you so much!
