Wednesday Wisdom: Using Monarch Utility to Convert Models/Projects
Rebecca_Cronin
Happy Wednesday!
Did you know you can use the Monarch Utility to help convert your Older Monarch models ( .mod or .xmod) to the latest supported Monarch Client version ( .dmod)?
This week’s piece of wisdom will explain how. Check out this resource: How to Convert Models/Projects Using Monarch Utility. Within the Monarch Utility Guide, end user should select the second option: Converting Text/XML Models or Projects to the Binary Format.
Hope this is helpful!
Rebecca
Rebecca Cronin
Manager, Customer Success
Chemlsford MA
(978) 275-8203
