I have created my first animation with Flux (see attached file). As you can see, the scale changes with each frame. Is there any way to keep the scale constant?
Yes, there is a way. When you open the window to create the animation, select display (see attached document). Form the display you have the possibility to control the min and max value of the displayed performance (isovalues, isolines….).
Thanks
