Hello,I was just about to do my first magneto static 3D simulation when I stumbled upon the following error message after the solving process:
Is there more detailed information where my error could be?
Thanks for your help in advice.
Sebastian
Hello Sebastian,
I need to look at the model setup for reason behind this error. Can you share the model with me?
Thank you,
Lavanya
Hello Sebastian, I need to look at the model setup for reason behind this error. Can you share the model with me? Thank you, Lavanya
this is my model.
